[SOLVED] Motherboard for the below listed parts?
Assuming youre set on just using mwave for everything?
Firstly Id swap the monitor out for a freesync panel & the 1060 for an rx 580.
https://www.mwave.com.au/product/aoc-c24g175-236-144hz-full-hd-1ms-curved-freesync-gaming-monitor-ac16613
https://www.mwave.com.au/product/asus-radeon-rx-580-rog-strix-top-edition-8gb-video-card-ac03873
Secondly , as fancy as that thermaltake psu looks its just not very good,quality at all.
The cx or cxm 550 is where you should be looking at a minimum.
https://www.mwave.com.au/searchresult?button=go&w=Cx550
Motherboards??
Mwave stock is limited in all honesty.
https://www.mwave.com.au/product/msi-b450-tomahawk-am4-atx-motherboard-ac16428
For me it would be the tomahawk from just that site on...
Motherboards??
For me it would be the tomahawk from just that site on a,price/performance basis.
Your selected ram ? You've actually linked a wireless adapter by mistake!
I just realised that too... here's the ram link - https://www.mwave.com.au/product/gskill-value-8gb-1x-8gb-ddr4-2666mhz-memory-ac18411
Is this monitor also a good option?(https://www.mwave.com.au/product/acer-kg251qf-245-full-hd-freesync-144hz-1ms-led-tn-gaming-monitor-ac12129) It has freesync but I dunno about getting a 580, can you tell me any pros besides freesync?
I might get the 580 anyway, not quite sure though.
Also are there any cheaper reccomended mobos.
Yeah the acer is a good screen , its tn as opposed the aoc which is va.
Va tends to give better colours & deeper,blacks, tn has better response times. These are trade offs between the 2 screen technologies.
If ypu are dead set on 144htz then I would honestly always recommend the rx 580 & a freesync screen if possible.
Freesync makes a massive difference to fps fluidity, dont underestimate it at all, the 580 is as strong as te 1060 in dx11, stronger in dx12 & imo will age far better a couple of years down the line.
Irregardless if you are set on nvidia steer clear of the asus turbo cards, theyre unbearably noisy under heavy load.
If I decide on 580 should I get
or
https://www.mwave.com.au/product/gigabyte-radeon-rx-580-gaming-8gb-video-card-ac03844
also out of these motherboards which one should i get or leave a suggestion below.
https://www.mwave.com.au/product/gigabyte-ax370m-ds3h-am4-micro-atx-motherboard-ac12564
or
https://www.mwave.com.au/product/gigabyte-ax370m-gaming-3-am4-micro-atx-motherboard-ac12562
or your suggestion
thanks for the help.
