Hello guys, I have 2 mobos fried in a span of 2 days when I was trying to set up a 5GPU rig.
Here is my specs
Mobo: MSI Gaming M3 and Asus Z270A Prime
RAM: Corsair 4GB
CPU: i3 6th Gen
GPU: 5 x Zotac 1060 6GB Amp Version
SSD: 128GB
PSU: Corsair RM1000X
Risers from Amazon [Ver 002 and Ver 003]
Ok, here's what I did. Connected all the necessary components and connected one GPU via riser on the 1x Slot, it gets detected and I installed the drivers. Same way, I installed 4 GPUs. When I connect the 5th one, it didnt get detected. So, I kept trying with different combination of connections on the 1x slots [MSI Mobo has 4 1x slots and 2 16x slots] no luck indeed. And at one try, mobo failed to boot and then it is fried. Intense heat can be felt just close to the 8 Pin. Along with the Mobo SSD and RAM is completely dead too [Tested on another PC]. I can see people setting up 8GPU with ease, I mean its just 5GPU, why can't my Mobo handle?
Is it the risers? Or did I miss something?
Ohh, forget to tell. I placed my motherboard on a a Wooden plank. Dont think there is any reason to short circuit due to this. My Asus Mobo on the other hand had a different problem. Before purchasing this, had a talk with the representative. He clearly mentioned, this mobo is optimized for mining purposes, so it would do more than just fine. But for me, it fried when I install the 3rd GPU. Then, its dead like the MSI.
In both the cases, a lot of people followed the exact same method as I did and they were successful, then why couldn't I ? All the components are brand new and purchased from the authorised retailers, except for the risers. So, is it really the risers causing the pain? or did I buy poor quality low version risers? And I powered the risers using a Molex to Sata cable. This way, I have powered more than 2 GPUs with one cable [Have 4 SATA outputs in 1 cable]. The other end is a six pin which goes to the PSU.
I have no idea. Now that I sent both the mobos for repair/replacement, I wanted to know what would have gone wrong so that I might get prepared once it is returned. Im open to all the suggestions and help, guys. Please help me through.
Here is my specs
RAM: Corsair 4GB
CPU: i3 6th Gen
SSD: 128GB
