motherboard front panel help
KTARO
11
hi, hope any1 can help me out, i recently bought a new pc case, and look at the front panel and the pc case, its different im not sure which leds to go which.. hope you can help
PC CASE CABLES
PWR LED 3 pin header but the middle one has no wires on it
PWR SW 2 PIN
SPEAKER 3 PIN
RESET 2 PIN
HDD LED 2 PIN
fferree
135
The information for the front panel connectors is in your motherboard manual. The connectors themselves come with the case. A tip I discovered is that there is a tiny triangle on the positive conectors. Follow the manual diagram.
PCD
124
Have you checked the manual for the motherboard?
What brand and model motherboard is it for? The frontpanel connector type you picture looks a bit like the one I've seen on some Chaintech boards. Some of the connectors are supposed to be placed vertically and not horizontally as is normal. There's likely a further group of connectors close the the group you have pictured. It may contain the PWR_On and 4pin PWR_LED connectors.
KTARO
11
my pc is PACKARD BELL IMEDIA 5109
TYPE OF MOTHERBOAD IS
Columbia (GA-8SIML) Ver 1.0 µATX motherboard
the diagram i got is from the packard bell website..
just not sure which one plugs into which >.< just dont want to plug into the wrong one
icute a04bh case
Speaker - 4 Pin slot - (Orange & Black Wires)
H.D.D. LED - 2 Pin Slot - (Red & White)
Power LED - 3 Pin Slot - (Green & White)
Reset SW - 2 Pin Slot - (Blue & White)
Power SW - 2 Pin Slot - (Orange & White)
Similar threads
