Motherboard Front Panel troubles
BoxxingBear
Commendable
Aug 6, 2016
I've recently been working on changing cases to a phantaom 410 elite and I am completely stumped on the problem of where I should hook in these Power sw, Reset se, and the led and what not to my panel pins. I've seen ton of answers on the topic to use the manual, however I don't have my manual and I can't seem to find my motherboard's number anywhere at all. It was a prebuilt PC from bestbuy and the model of the case was a cm6830-06, but I can't find the motherboard model anywhere. Looking inside the motherboard, the only white strip that could possibly give me information is this line of numbers and letters.
0230310-05085-PA0130-A19 3602 Y59039
I'm unsure if the numbers are any help. The Panel at the bottom right is quite odd. It has no real labels (probably in the manual). It's white and some prongs are there and some prongs aren't present. I really need help. Also the Manufacturer is Asus. I'm sorry I'm not very computer savvy but it would mean a lot if I could get assistance.
TLDR: Unsure what motherboard model it is. Have no manual. Premade computer bought at bestbuy. CM6830-06. Can't find polarities of front panel pins for the motherboard.
