Motherboard geniuses.. help! how do i disable onboard sound -ASUS mobo-
Gardnersworld1
118
First off, I KNOW this is one hell of an ask, because the chances are you guys definitely do not have the same motherboard as me, but MAYBE, just maybe asus motherboards all have the same bios.
Anyway I am going to get a sound card in around 3 days time so I was just looking in the bios as to how to disable my onboard sound. (I have an asus p8z68-v pro gen 3 motherboard).
So I went into advanced and the only option relating to audio that was there was 'hd audio manager'. The 'manager' part threw me off a bit.. To me that does not sound as though it is my onboard sound.
Is there anyway I can cut corners here and disable my onboard sound without having to go into the abyss of the bios!? I don't like the bios. It's scary.
I found it,
goto 'advance mode' which is top right corner.
Goto to the 'advance tab' and select 'onboard device configuration'.
Then 'disable' HD audio Controller.
From what i remember 20 minutes or so ago when i check there was DEFINITELY no integrated peripherals section
This youtube video is LITERALLY my bios, would one of ya mind spotting it out for me please?
