When turning on the laptop, except for lights coming on, nothing happens. After a while the ODD's making noise, like if it's trying to read a disc that isn't there. It keeps on making this sound at even intervals, around 5-6 seconds apart.
The CPU-fan is not turning on right away, but it does go on after a while when the CPU starts to heat up. So, apparently it's trying to do work. Or does CPUs get warm even if they don't get any instructions?
I tried unplugging the RAM and powering on expecting some beepcodes, but nothing. I also removed the CPU to see if the ODD kept on making noise, maybe it tries to boot from DVD or something. But, with CPU removed it still makes noise with regular intervals, Without a CPU it's impossible it's trying to boot.
So I just want some second oppinions on this, the motherboard is busted right? Even if the CPU seems to be working, and the motherboard is able to keep track of the temp, it still doesn't do anything different no matter what components I remove.
I also tried plugging in a second monitor, no visual at all either on laptop or external monitor.
