Motherboard, Graphics Card & CPU not compatible
trickrickmusic
43
So here is the story.
I have an old motherboard, an Intel DP55WB. I decided to buy a new GPU (ASUS AMD Radeon R9 380) and after speaking with Intel support, it turns out that it is incompatible with the BIOS in my motherboard. I then decided that I would upgrade my motherboard, but the socket is also pretty old (LGA 1156). So I would also have to upgrade my CPU which is actually pretty good (i7 860).
I can't seem to find decent socket 1156 motherboards and even then I still risk having a compatibility issue with my graphic's card.
Can anyone think of a workaround? Like getting a different motherboard which will be compatible with my LGA 1156 CPU? This is a pain, I didn't know computer technology changed so fast before trying to upgrade.
Thank you.
Wow, I never have heard of that. Well I learn something new every day :)
I would go with the...
I know it is odd... I've got the latest BIOS too. It has to do with my motherboard's BIOS being legacy and the GPU's being UEFI or something, not sure what it means though.
Thank you elbert, I appreciate the help. I have a lot of softwares and plugins that would be extremely hard to reinstall, do you think I could install this motherboard without reinstalling my OS?
After trying everything, uninstalling old drivers, safe boot, resetting CMOS etc etc I always freeze on the BIOS at startup. I've tried over 10 techniques which do not work. That is when I contacted Intel support and they told me that if it didn't work with the latest BIOS, they weren't compatible. I know this is a rare incompatibility issue but it's real. My old graphics card works just fine as it's running right now.
I have 3 slots of space below my motherboard. I should be good for a full ATX. I would like a motherboard that wouldn't require a fresh install though!
I would go with the Asus Mobo, IMHO, since they seem to be on top of their game most of the time and are usually pretty stable and reliable too.
Thank you! After reviewing them, I think I'll go with the MicroATX Asus.
