Motherboard hardware monitoring don't work
Annons
Commendable
Nov 24, 2016
5
Hello. I have a problem with fan controlling and hardware monitoring in bios. Hardware monitoring when in bios just don't work. It shows 126c cpu temperature and when I click on hardware monitoring current information is 255c on both cpu and system, and the rpm is 0. Here are the pics http://tinypic.com/r/314csb9/9 http://tinypic.com/r/2u8j6ki/9. Open hardware monitor shows normal temperature. http://tinypic.com/view.php?pic=14jsz86&s=9#.WDbh2tUrJQI
Speed fan isn't working either. I'am using the Phanteks Enthoo pro case, and their fan hub is connected in cpu_fan header. I don't think it's the hubs fault because I tried to use 4pin fan in cpu header and its the same.Here are mine system specs
Motherboard: MSI B85M-E45
CPU: Intel i3-4150 3.50GHZ
Graphics: GTX 760 2gb
Ram: DDR3 8gb (2*4gb) 1333
Thanks in advance.
P.S. This is my first time asking on a forum for help
Tried your method. Didn't work. I had management engine and deleted mine. Tried to install that one from your link, it's not supported. Chipsets newest driver is installed, bios is latest. I forgot to mention I have 2 windows 7 installed on separate HDD. One hdd have meny bad sectors but I use it for storage.
I have latest bios installed. Thing is I can't controll fans in any way. Not via bios or any software. Temperature readings are correct using any software but not in bios. I need to controll cpu_fan. Thats my real problem.
