[SOLVED] Motherboard has 4+4 and another 4 pin connector for the CPU. Necessary?
Mar 24, 2020
29
I bought a msi mpg z390 pro carbon board and it has an extra 4 pin slot for the cpu power. Is is really necessary to plug it in.? When would you need to use it?
XxDarkMario20xX
843
81
5,190
40
Could it be this?
the extra 4-pin CPU power connector, labeled as "CPU_PWR2" is for supporting additional power (75W +12V) to the CPU if you OC your CPU. Plugging EPS2 power cable into CPU_PWR2 is optional and isn't needed for normal operations of MoBo.
XxDarkMario20xX
843
81
5,190
40
Could it be this?
Mar 24, 2020
29
Could it be this?
Yes that was it thanks. Would it be good to plug it in for overclocking? have a i9 9900k
Mar 24, 2020
29
If you have a plug on the power supply, and socket on the motherboard, why would you not connect them? What's the gain? Connect them and be done with it.
See I don't think i have the plugin on my power supply for it. Iwas wondering if it was some other kind of 4 pin connector
Oh, I see. My bad. :(
Well, as others have said you don't necessarily need it (although i would check the motherboard manual to confirm).
That being said, if the engineers put it there I'd see if I can't get a beefier power supply with that connector on it too--just to be safe.
Reactions: MatthewPav
Mar 24, 2020
29
I'll look to it in the future. I already ordered it and its hard to get this stuff anyway because I'm outside of the country with the military
