[SOLVED] Motherboard has no 2 pin header
Apr 9, 2021
How can I use a 2 pin temp sensor on a motherboard that has no 2 pin header? Is there a pci-e card that I can use that will accommodate a 2 pin sensor?
Been a while since I have seen a discrete temperature sensor. I'm sure some higher end boards still have them though, again, not seen one used.
Basically need a ADC card (Analog to Digital Controller) I'm sure they are out there, but you would have to get the spec sheet for the temperature sensor, and possibly write your own software.
Buying something like a USB -> temperature sensor would make more sense.
Reactions: spruitt626
