Motherboard has USB 3.0 while case front panel only has USB 2.0
GrannySmith1
185
So my motherboard here has USB 3.0: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
My case however only has front panel usb 2.0 ports: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
What does this mean? I need to buy additional headers or adapters or will my motherboard also have an option on board included for USB 2.0? I don't quite understand yet how all this USB crap works. For front panel USB cables, you need a power cable that goes from MOBO USB to front panel right?
In this case we have a MOBO with USB 3.0 header while front panel has USB 2.0. What do I do?
How do I even know if mines does? I checked on newegg in description but I do not see anything that confirms this.
Just making sure, a USB 3.0 to USB 2.0 cable adapter will plug into the USB 3.0 on the mobo, convert the signal to USB 2.0 and then plug into the front panel correct? Again, just making sure.
