Hello. I need some advice on a motherboard.
Option 1: Asus P8Z77-V: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131820&nm_mc=AFC-C8junctionCA&cm_mmc=AFC-C8JunctionCA-_-Motherboards+-+Intel-_-ASUS-_-13131820&AID=10592396&PID=3938566
Option 2: ASUS P8Z77-V LK LGA: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131837
Option 3: ASRock Z77 Extreme4 LGA 1155: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157293&nm_mc=AFC-C8junctionCA&cm_mmc=AFC-C8JunctionCA-_-Motherboards+-+Intel-_-ASRock-_-13157293&AID=10592396&PID=3938566
My current build: http://pcpartpicker.com/ca/p/xCLP
If you have better motherboard options that would be great aswell. Budget for a motherboard is anything under $200.
Computer will be used for gaming and multimedia. No video editing.
