A friend of mine suggested a build for a PC within a budget range and I have most of the parts recommended but one bundle, and here they are:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231489
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150588
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
He suggests that I should go for this combo to finish it off:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1067585
Is there a cheaper route for the motherboard combo that's as good or up there with it?
