[SOLVED] Motherboard help
elijahjue
7
Hello All I have a problem I'm hoping you can help me with I'm having to replace my Motherboard in a home built PC and not rely sure on what I'm doing. This is the PC build as it stands now
MSI MPG X570 Gaming PRO Carbon WiFi Motherboard (AMD AM4, DDR4, PCIe 4.0, SATA 6Gb/s, M.2, USB 3.2 Gen 2, AX Wi-Fi 6, HDMI, ATX)
XPG SX8200 Pro 512GB 3D NAND NVMe Gen3x4 PCIe M.2 2280 Solid State Drive R/W 3500/3000MB/s SSD (ASX8200PNP-512GT-C)
CORSAIR RM Series, RM850, 850 Watt, 80+ Gold Certified, Fully Modular Power Supply, Microsoft Modern Standby
Windows 10 Home 64 bit / 32 bit | USB Flash Drive | English New
AMD Ryzen 7 3700X 8-core, 16-Thread Unlocked Desktop Processor with Wraith Prism LED Cooler
MSI GAMING GeForce RTX 2080 8GB GDRR6 256-bit HDMI/DP/USB Ray Tracing Turing Architecture Graphics Card (RTX 2080 VENTUS 8G OC)
Hitachi HUA723030ALA640 3TB Hitachi UltraStar 7K3000 HUA723030ALA640 7200RPM SATA Hard Drive
I was thinking of using this but not sure if it will be the absolute best choice
Corsair Vengeance RGB PRO 128GB (4x32GB) DDR4 3000 (PC4-24000) C16 Desktop Memory – Black (CMW128GX4M4D3000C16)
to replace the Motherboard with the same thing will run me $400 and that a little steep for me at the moment so I'm hoping to find something cheaper that will work. I saw this but not sure if it's compatible and it's still a little pricy
MSI MPG X570S Carbon MAX WiFi Gaming Motherboard (ATX, AMD, Socket AM4. DDR4, PCIe 4, CFX, M.2 Slots, Wi-Fi 6E)
Any help would be greatly appreciated
Replacing the X570 should not be an issue and something like this will do more than a good job:
$219
https://pcpartpicker.com/product/WK...fi-atx-am4-motherboard-mag-x570-tomahawk-wifi
$198
https://pcpartpicker.com/product/dm...tx-am4-motherboard-tuf-gaming-x570-plus-wi-fi
Even a decent B550 will do a good a good job
https://pcpartpicker.com/product/3Mxbt6/msi-mag-b550-tomahawk-atx-am4-motherboard-mag-b550-tomahawk
This might help from Hardware Unboxed who are vey good on motherboards
X570
View: https://www.youtube.com/watch?v=OMRUhtMs9Ok
B550
View...
It's corrupted and won't let me start the pc when it dost startup it takes 45min. to get to windows if it even doses consistently crashes keeps losing drivers it's causing a tun of problems I had a tec. come out and look it over and he along with others recommend replacing the board
