So I am the middle of building my new machine and I was about to buy and was torn between these really good Asus motherboard and really good Gigabyte motherboard, however I researching and stumbled upon a very attractive motherboard that happened to be made by INTEL! I liked it because it:
-Supported Core i7
-Had LGA 1366 Socket
-Had 4x 240 pin memory connectors
-Had QPI 6.4GT'/s
-Supported 1600mhz ram
-Was Triple channel
-Supported up to 16GB memory
-Had 8USB ports
-And 2 SATA 3GB connectors
-Costs 243.99$ on New Egg, its called the:
Intel BOXDX58SO LGA 1366 Intel X58 ATX Intel Motherboard
Here is a link to it on new egg, where it gives its specs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121361
I dont know about what you guys think, but I think this motherboard is excellent, becuase the next motherboard that supported my desired 1600mhz ram without having to overclocking was a lot more expensive!
-I wanna see what you guys think!
-Supported Core i7
-Had QPI 6.4GT'/s
-Was Triple channel
-Had 8USB ports
