[SOLVED] Motherboard LED Warnings on Startup
qhobbes
15
Hey all,
I have a Z390 AORUS PRO WIFI motherboard. I built my PC several months ago and it runs just fine. However, when powering it on (even upon waking up from rest mode), the red LED warning lights flash.
According to the manual that means that either the RAM, VGA, CPU, or operating system are not functioning normally. The strange thing is that everything works fine but I still get these lights.
Yesterday it gave me the RAM, then VGA, then OS light.
I just now powered off, re-seated the RAM and powered on to test. It showed the CPU light, then RAM, then VGA, then OS light in order.
Despite this, everything works fine. Should I ignore it?
That what it suppose to do. check each components during boot
Thank you for your response. I understand that is its function, but I guess my question is whether or not I should be worried. It is saying something isn't functioning normally but the PC has been functioning normally for months. Should I begin troubleshooting to make the lights go away or just wait until there is a clear error and then begin?
