Question Motherboard LEDs and RGB headers not working; Asus Aura Sync
DiegoBoricua
74
I have an Asus Strix Z370-E mobo which has worked flawless, including the RGB... until now...ish.
I just noticed that the ARGB leds on the motherboard and the RGB headers are not working (NOTE: The ARGB Header DOES work). Aura Sync even notes the Mobo as present. Note that even before when they were working, the RGB Headers and Mobo seem to run on the same signal.
I am unsure how long its been this way, so I have no clue as to how it was caused. At this point, I'm unsure what the issue is at all
Troubleshooting done already:
- Installed latest BIOS​
- Uninstalled and reinstalled Aura Sync (Multiple times, including various versions, both latest and those noted to be working by other forum posts)​
- Turned off and on RGB via BIOS​
- Physically disconnected and reconnected RGB plug.​
- Moved RGB Header connections; I don't have another system to test the fan RGBs on.​
This seems to be a unique issue for me.
Please, let me know if you have any solutions that may help.
