I tried using a screw driver to connect the two pins that the power button runs do, but nothing happened. The system was fine when I turned it off about a year ago. I took the hard drive out to use as a back up in my new build but when I tried booting my old build (the pc in question) it failed to start.
I tried reseating the power button connector, no go. Then I tried the paper clip test and the fans powered up. I then tried a screw driver to the two power button pins but nothing happened.
I looked through the manual but couldn't find a manual power switch anywhere.
The mobo is an Asus M2N4 SLI. The PSU is a ln OKIA 600ATX.
I hope the mobo isn't fried and don't see how it could be because it functioned fine the last time it was powered down. 🙁
