Motherboard lighting problem
Zahid Shabir
267
I have the Asus Strix Z270h and it has a red LED line showing where the audio is isolated from other components. Not sure if it is RGB but i do not want a red LED showing there. Is there a way to change the colour (if it is RGB) or turn it off. I installed Asus aura software and it installed as GPU software (i have Asus Strix Rx480) even though i did not install GPU specific do not want a red LED showing
already tried that and could not find anything relating to lights on my bios but i am pretty certain if it is not RGB then that is the only way
just found it was in the bios but it was very hard to find the part of the bios which had this had nothing to do with it but i had to manually check each tab and setting to find it took a long time to find it
