Motherboard NO built in WiFi (Help!)
Nov 14, 2018
Hi there,
I have purchased the z370 A Pro mobo which doesn't not have built in WiFi, how can I get WiFi on my new PC when it's built?, And, what would be the best option.
Thanks in advance.
Either PCIe Wifi card, or a USB dongle.
PCIe devices are usually better quality, although appear more expensive. ($30-$40 for something solid)
USB devices appear cheaper, but the quality ones can be ~$50. The cheap/generic devices offer either no moveable antennas, or lack driver support and I would avoid those. A quality USB dongle is a good option, but you'd end up paying more.
PCIe @ $35.
https://pcpartpicker.com/product/6Zs8TW/asus-pce-ac55bt-b1-none-wi-fi-adapter-pce-ac55bt-b1
USB 3.0 @ $50.
https://pcpartpicker.com/product/dmYXsY/asus-wireless-network-card-usbac56
I've used this one, it's a great little dongle. Great range etc, but if you have an available PCIe x1 slot (you should!), then I'd opt for that kind of solution.
