Question Motherboard no power ?
autoblogart
359
8
18,695
Hey how is it going
I ran into a weird issue guys
1) The motherboard have no power at all .
I have tried to take out the mobo from pc case and put it on a wood table non static
2) i have tried to check a psu manually with a paper clip and the fan is spining non stop
3) i have tried something . I took the 24 pin from the motherboard and only left the 4 pin connected and i started the directly the psu with paper clip and the pc cpu fan and psu started .
But when i plug the 24 pin in mobo and try to turn on from mobo power sw pins it doesnt start at all
My specs
I5 2500k
Mobo : Foxconn 2abf
8gb ram ddr3
Gtx 650 1gb
Psu is advance mpt 5002 (500w)
The mobo was working Fine until it happened yesterday
Has it ever worked?
What motherboard?
I'd probably start by getting a new, brand name PSU.
Yes it was working before and yesterday the problem occured .
By the way i have tried now . To plug the 4 pin 12v into the mobo and unplug the 24 pin and starg directly with a paper clip the psu and it started but when i plug the 24 pin and try to start from the mobo power sw pins it doesnt start
Mobo foxconn 2abf
