Motherboard not getting power
sushil151986
Hello,
Resentlly Due to some problem i was replace my gigabyte motherbord in company warranty.
But now the problem is the mother bord is not working with my system as bord not geting power from my sytem, same bord i again check with service center but there they show me that the same bord is working properly, i dont undrestatnd the prblem as my other part of PC like RAM, Processer SMPS is well as i check the same with other PC. Can you pls suggess me the solution.
greddy23
69
hmmm are you sure the 24 pin cable is plugged in into the motherboard? from what i read you say this is a replacement motherboard and you say that you have tried your processor and ram on another computer and they are fine.
Well can you check if the power supply is not faulty?
aneeshkumar
57
4
looks like a PSU problem as greddy said.. there is a simple loopback test for PSU who dont have multimeter to check PSU. Get a paper clip(or any good conductor with similar dimensions) and insert one end to the green cable hole in the 24pin connector and the other end to any black cable hole. if the fan is not rotating, your PSU is not working..
sushil151986
Hi Greddy,
I alredy check power supply unit & its also working well. also i connect my friends PCs PSU but still the result is same
Similar threads
