MOTHERBOARD NOT WORk!!!!!
rootb1796
Commendable
Feb 25, 2016
5
I replaced my PSU because it was making a grinding noise like a cricket. The comp worked fine before I removed the PSU.
I chose a Corsair HX750i for the replacement. I unplugged all power before removing the old
PC WILL NOT BOOT, NO POST, NO BEEPS, NO DISPLAY. MOTHERBOARD?
PSU. After plugging in the new Corsair PSU the computer will not boot. I have some power because case fans, CPU fan, Graphics card fans spin, USB mouse lights up, and Ethernet cable shows communication.
I tried plugging in the old PSU again and it no longer is working. Same results as the new PSU.
I also reset CMOS Battery.
Working
I have a motherboard light indicating power
CPU fan spins up
USB mouse lights up
Ethernet cable has lights showing traffic
Not working
Graphics card does not push display to either HDMI monitor or DVI monitor - both show orange lights
USB Keyboard does not light up
Computer does not shut down when power button is held in.
Parts:
PSU: Corsair HX750i (brand new) or Apevia Java 650W (old)
Motherboard: Asus M5A97 LE R2.0
CPU: AMD FX-8350 Black Edition Vishera 8-core 4.0 GHz (4.2 GHz Turbo) Socket AM3+
Graphics card: PowerColor TurboDuo Radeon R9 280x
SSD: Samsung 850 EVO 2.5
RAM: Gskill Ripjaw F3-12800CL9s-4GBRL DDR3-1600 PC3-12800 4BGx1
Gskill Ripjaw F3-12800CL9s-16GBRL DDR3-1600 PC3-12800 16BGx1
Thank you.
Do you have both the 24 pin and the 4/8 pin power connectors to the mobo - also make sure the 4/8 is in fact the EPS connector and not a 8 pin or 6+2 pin PCI-E power connector
