I got a PC back from a friend.. so refreshing it for my brother. First issue.. my USB keyboard is not recognised from boot, if I unplug and replug it in.. it detected OK. Keyboard is fine on my PC.. and another keyboard works fine on the PC. So I assume a dodgy keyboard and move on.
But when I reinstall Windows.. after it downloads and restarts.. I get no display.. but display comes back at end. I retest keyboard issue (in case it was a bad Windows issue) and keybboard still not recognised from boot.. but is when unplugged/replugged in. But I start to get "random" display issues (e.g. Boot post will show sometimes.. but not others).. so I check.. and it seems like sometimes it will use the discreet GPU and sometimes it will output to onboard graphics.. and sometimes both. Sometimes discreet work from boot.. but when I restart, no GPU display again.
So I go to BIOS and tell it not AUTO, but specifically to use discreet GPU as primary.. but the setting does not stay fixed in BIOS.. keeps resetting to "CPU" graphics..
More testing.. and it seems like it is not reliably detecting the discreet GPU (presumably why BIOS resets my setting, if it cant detect a GPU in PCIe slot).. I swap Graphics card but have same issue (may be even worse.. detects if less often). I reflashed BIOS.. just to check that got corrupted.. and reset (removed BIOS battery for 30 secs) to just try ensure BIOS reset and clear. Still having problems.
So given all this.. what you think? Motherboard on way out? could dodgy power supply account/explain all this?
Help please.. its driving me crazy!!!
Motherboard is a ASUS Prime H310M-K ver 1
Graphics cards I tried GTX 960 and GTX1060 (both worked fine in another PC when I last checked)
Thanks in advance for any insight.
