[SOLVED] Motherboard options for ryzen 5 3600 and rx 580
rdhaval01
67
Hey guys.. I have recently bought ryzen 5 3600 and have paired it up with Rx 580 gpu. I am confused regarding which motherboard I should go with that will be compatible with the cpu and gpu mentioned above. I have checked out many motherboards that supports ryzen 3rd gen but I got to know that many of them have bios updation problem. So I am looking out for a motherboard that would work out of the box for ryzen 5 3600 and it will not require to update the bios. Any suggestion would be highly appreciated. Thank you.
My system specs are as follows
Ryzen 5 3600
Rx580
Psu 550w
8gb RAM
240gb ssd
1tb hdd
Go for x570 Gigabyte Aorus Elite/Master or Asus Tuf. B450 MSI Tomahawk Max. All above are high quality.
X570/B550 have native Gen3 support. So does most B450 boards now. MSI did re-release it's own under the Max brand to guarantee compatibility from box. Other brands will have to rely on factory release date which can be hard to determine unless a verification sticker.
