• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Motherboard or CPU Problem
Jun 27, 2020
My computer stopped working a few years ago but I decided to try and fix it now because I have nothing else better to do.
Here's the problem:
A few years back before my computer stopped working something happened.
While playing games some of the fans suddenly stopped ( I noticed beacause the fans on my pc make audible noise then it suddenly disapperead and I also hovered my hand on the holes and air wasn't flowing through ) but thr PC was still on so i kept playing.
The next day I tried turning it on but it won't, that brings us to today. I disassembled my PC to diagnose the problem.
Here's what I found:
-The power supply still works. When I connected the green wire (Postive) to thr black wire (Ground). When I connected a fan it worked so it was fine
-I connected the power supply to the motherboard (With the green wire still connected to the black wire). When I connected the CPU fan to the motherboard it worked.
-I connected the SATA Power to thr HDD it the drive turned on.
-Then the wierdest thing happened. When I connected the wire the powers the CPU, everything turned off, even the fan on PSU.
-Then I removed the wire, turned the system off then on again, then all the fans and even the HDD turned on again.
-The I tried conneting the VGA to a monitor and it just says "No Video Output".
-If the green wire and black wire are not connected even if the PSU is connected to the motherboard, nothing turns on.
*Note - The RAM is installed in each scenario.
I just would like to know if the motherboard is at fault or the CPU. And if anyone can help fix this problem.
