motherboard or memory issue
cheriley
8
mobo g41m vs3 r2.0
cpu intel e5800
mem 2x4 hyperx fury ddr3 1333
will not post
no memory fault beep
power supply and cpu verified working
no visible damage to mobo
peripheral issues ruled out
mismatched memory?
bad board?
favoring bad board due to no fault alert
well your board supports 1333 but it has to be overclocked to see that speed. and when you put a memory in it downgrades to 1066 until you go into bios and change it to 1333.
lets reset your cmos. Unplug everything. unplug the power supply unplug the 24pin and the 4 pin and locate the cmos battery it's behind the white PCI express slot. leave the Cmos battery out for 15 mins so all the power get's drained and it reset's. then put it back in and connect everything back. Make sure your RAM's are properly placed too.
BEFORE doing what i told you. i want you to do one thing. Even if you think you have connected the Memory correct redo it. Take out the memory Put it in straight half way then click the left side in (where there is no lock) then when you are Pushing in the side where there is a lock push it in hard and fast so the Auto lock, lock's in by it's self. if you have to push up the lock then you did not do it correctly.
still nothing with mem installed correctly. battery out now. i really think its the board now. with no mem installed it still doesnt beep. its a new board so not sure what cmos would have to do with it but hey why not
well that motherboard is not going to beep because it does not have a Debugger or a case speaker built in. here is a case speaker that will make the motherboard beep
http://www.newegg.com/Product/Product.aspx?Item=N82E16812201032&cm_re=case_speaker-_-12-201-032-_-Product. idk you buy this and try it with the case speaker installed and test it like that before RMAing the motherboard.
