I have just built a system comprising the Fata1ty B450 K4 gaming M.B, a Ryzen 5 3600, 8Gb ram, and installed it into a new case with a 500w power supply.
The only other part added is a Gigabyte 1733 wi-fi adaptor. I had to use extension leads so that the 24 pin and 4 pin power leads could reach the appropriate slots.
The M.B. headers are in the correct place with the correct + & - placement. I have usb 3 output to a separate hub with 6 slots to it.
All connected as per expected but when I switch on at the main on/off at the power input, there's some red flashing taking place from a very small nodule of sorts just to the right of the system battery. The usb hub light come on though they seem to constantly move from dim to bright. There is no light on the top of the case to show power, hdd activity etc and of course the power button doesn't start things going, nor does pressing the reset switch.
Now, and this may be crucial, on opening the box with the ryzen cpu it fell out and bent a few pins on the kitchen floor. I straightened them out with ease, didn't snap one off either. However given that, is it more than likely this whole problem is geared around the cpu? If the cpu was knackered, would the other system components such as fans, header lighting etc be disabled as a consequence. Whatever it is, I am confident that all leads, headers are correctly connected. Any ideas guys?
