Motherboard Overheating Problem
freeofavia
Commendable
Apr 12, 2016
Seemingly since upgrading to windows 10, my pc has been overheating and freezing while playing games. At first I thought i was using too many mods in skyrim, but even a low graphics game like firewatch has been experiencing stuttering and freezing. After i've been playing a game for a while, sometimes 10 minutes, sometimes 2 hours, the game will freeze. The last moment of audio will repeat itself rapidly, like a machinegun, causing a terrible noise. Sometimes the pc will recover, most of the time not. Whenever this happens, i need to manually shut it down by holding the power button. Inside, the video card is hot, the heatsink is warm, but the chipset on the motherboard, oh lord it is HOT!
Essentially, i'd rather replace the parts i need to then try to fix them, but i'm not sure if I have faulty parts or if there is some other problem.
I have cleaned my pc out a second time, using canned air to spray off the components, which didn't seem particularly dusty. And I cleaned my air filters, which were pretty dusty. I have 3 case fans, stock gpu cooler, and a Cooler Master Hyper T2 heatsink. GPU drivers and os are up to date.
I got a motherboard that was probably cheaper than what I should have got, so that may be the problem. Specs are below.
If anyone can let me know what troubleshooting steps are necessary to isolate the problem, I would greatly appreciate it!
■ OS- Windows 10 Pro 64-Bit (10.0, Build 10586)
■ GPU - Sapphire Radeon r9 280
■ CPU- AMD FX(tm)-6300 6 core processor (6 cpus ~3.5 ghz
■ Memory - 8192 gb ram
■ DX version- 12
■ Motherboard- MSI ms-7693 (970a-g45)
Edit: So the computer froze again, this time i restarted, i opened a single window in my browser (the page you're looking at now) and my computer froze again! Assumingly because it was still hot. I restarted again after letting it sit for one minute, and opened up the bios. My cpu temp was 50 degrees. So im thinking it's not the cpu.
It crashed again during a gamed, and i restarted and looked at the temp as quickly as i could. 56 degrees celsius on the cpu, 38 degress on the mainboard system. I'm not sure ho to check the gpu.
I used Open Hardware Monitor to monitor my hardware temp and usage periodically while playing firewatch. I saved a report when i first started, another report when it started lagging, and a third report, which I will include in spoilers below. This report was taken just a minute or two before another crash/freeze. Nothing seemed out of the ordinary to me.
Open Hardware Monitor Report
Version: 0.7.1.0
Common Language Runtime: 4.0.30319.42000
Operating System: Microsoft Windows NT 6.2.9200.0
Process Type: 64-Bit
Sensors
+- MSI 970A-G46 (MS-7693) (/mainboard)
| +- Fintek F71889AD (/lpc/f71889ad)
| | +- VCC3V : 3.2 3.184 3.28 (/lpc/f71889ad/voltage/0)
| | +- CPU VCore : 0.888 0.888 1.48 (/lpc/f71889ad/voltage/1)
| | +- Voltage #3 : 1.064 1.056 1.096 (/lpc/f71889ad/voltage/2)
| | +- Voltage #4 : 0.872 0.872 0.88 (/lpc/f71889ad/voltage/3)
| | +- Voltage #5 : 0.592 0.592 0.608 (/lpc/f71889ad/voltage/4)
| | +- Voltage #6 : 1.344 1.328 1.352 (/lpc/f71889ad/voltage/5)
| | +- Voltage #7 : 1.6 1.592 1.64 (/lpc/f71889ad/voltage/6)
| | +- VSB3V : 3.184 3.184 3.264 (/lpc/f71889ad/voltage/7)
| | +- VBat : 3.184 3.184 3.216 (/lpc/f71889ad/voltage/8)
| | +- Temperature #1 : 63 45 64 (/lpc/f71889ad/temperature/0)
| | +- Temperature #2 : 53 43 53 (/lpc/f71889ad/temperature/1)
| | +- Temperature #3 : 41 33 41 (/lpc/f71889ad/temperature/2)
| | +- Fan #1 : 2722.32 2702.7 2782.93 (/lpc/f71889ad/fan/0)
| | +- Fan #2 : 904.159 651.891 942.803 (/lpc/f71889ad/fan/1)
| | +- Fan #3 : 1092.5 1075.27 1113.59 (/lpc/f71889ad/fan/2)
+- AMD FX-6300 (/amdcpu/0)
| +- Bus Speed : 200.004 199.998 200.012 (/amdcpu/0/clock/0)
| +- CPU Core #1 : 1400.03 1399.99 4100.13 (/amdcpu/0/clock/1)
| +- CPU Core #2 : 1400.03 1399.99 4100.13 (/amdcpu/0/clock/2)
| +- CPU Core #3 : 1400.03 1399.99 4100.19 (/amdcpu/0/clock/3)
| +- CPU Core #4 : 3800.07 1399.99 4100.13 (/amdcpu/0/clock/4)
| +- CPU Core #5 : 3800.07 1399.99 4100.14 (/amdcpu/0/clock/5)
| +- CPU Core #6 : 1400.03 1400 4100.13 (/amdcpu/0/clock/6)
| +- Core #1 - #6 : 51.75 27 51.75 (/amdcpu/0/temperature/0)
| +- CPU Total : 43.2292 0.520831 97.3958 (/amdcpu/0/load/0)
| +- CPU Core #1 : 57.8125 0 100 (/amdcpu/0/load/1)
| +- CPU Core #2 : 32.8125 0 100 (/amdcpu/0/load/2)
| +- CPU Core #3 : 51.5625 0 98.4375 (/amdcpu/0/load/3)
| +- CPU Core #4 : 21.875 0 98.4375 (/amdcpu/0/load/4)
| +- CPU Core #5 : 45.3125 0 100 (/amdcpu/0/load/5)
| +- CPU Core #6 : 50 0 98.4375 (/amdcpu/0/load/6)
+- Generic Memory (/ram)
| +- Memory : 40.7224 22.1298 42.7268 (/ram/load/0)
| +- Used Memory : 3.2377 1.75946 3.39706 (/ram/data/0)
| +- Available Memory : 4.71296 4.55359 6.19119 (/ram/data/1)
+- AMD Radeon R9 200 Series (/atigpu/0)
| +- GPU Core : 1.219 0.95 1.219 (/atigpu/0/voltage/0)
| +- GPU Core : 940 300 940 (/atigpu/0/clock/0)
| +- GPU Memory : 1250 150 1250 (/atigpu/0/clock/1)
| +- GPU Core : 80.125 35.5 80.25 (/atigpu/0/temperature/0)
| +- GPU Core : 95 0 100 (/atigpu/0/load/0)
| +- GPU Fan : 2500 1401 2547 (/atigpu/0/fan/0)
| +- GPU Fan : 59 33 59 (/atigpu/0/control/0)
+- ST3000DM001-1ER166 (/hdd/0)
| +- Temperature : 40 38 41 (/hdd/0/temperature/0)
| +- Used Space : 27.744 27.744 27.744 (/hdd/0/load/0)
+- SanDisk SDSSDHP256G (/hdd/1)
| +- Temperature : 52 38 52 (/hdd/1/temperature/0)
| +- Used Space : 59.8798 59.8713 59.8798 (/hdd/1/load/0)
Parameters
| | +- VCC3V (/lpc/f71889ad/voltage/0)
| | | +- Ri [k?] : 150 : 150
| | | +- Rf [k?] : 150 : 150
| | | +- Vf [V] : 0 : 0
| | +- CPU VCore (/lpc/f71889ad/voltage/1)
| | | +- Ri [k?] : 0 : 0
| | | +- Rf [k?] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #3 (/lpc/f71889ad/voltage/2)
| | | +- Ri [k?] : 0 : 0
| | | +- Rf [k?] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #4 (/lpc/f71889ad/voltage/3)
| | | +- Ri [k?] : 0 : 0
| | | +- Rf [k?] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #5 (/lpc/f71889ad/voltage/4)
| | | +- Ri [k?] : 0 : 0
| | | +- Rf [k?] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #6 (/lpc/f71889ad/voltage/5)
| | | +- Ri [k?] : 0 : 0
| | | +- Rf [k?] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- Voltage #7 (/lpc/f71889ad/voltage/6)
| | | +- Ri [k?] : 0 : 0
| | | +- Rf [k?] : 1 : 1
| | | +- Vf [V] : 0 : 0
| | +- VSB3V (/lpc/f71889ad/voltage/7)
| | | +- Vf [V] : 0 : 0
| | +- VBat (/lpc/f71889ad/voltage/8)
| | | +- Vf [V] : 0 : 0
| | +- Temperature #1 (/lpc/f71889ad/temperature/0)
| | | +- Offset [°C] : 0 : 0
| | +- Temperature #2 (/lpc/f71889ad/temperature/1)
| | +- Temperature #3 (/lpc/f71889ad/temperature/2)
| +- Core #1 - #6 (/amdcpu/0/temperature/0)
| +- Temperature (/hdd/0/temperature/0)
| +- Temperature (/hdd/1/temperature/0)
Mainboard
SMBIOS Version: 2.7
BIOS Vendor: American Megatrends Inc.
BIOS Version: V2.7
System Manufacturer: MSI
System Name: MS-7693
System Version: 2.0
Mainboard Manufacturer: MSI
Mainboard Name: 970A-G46 (MS-7693)
Mainboard Version: 2.0
Processor Manufacturer: AMD
Processor Version: AMD FX(tm)-6300 Six-Core Processor
Processor Core Count: 6
Processor Core Enabled: 6
Processor Thread Count: 6
Processor External Clock: 200 Mhz
Memory Device [0] Manufacturer: A1_Manufacturer0
Memory Device [0] Part Number: Array1_PartNumber0
Memory Device [0] Device Locator: A1_DIMM0
Memory Device [0] Bank Locator: A1_BANK0
Memory Device [0] Speed: 0 MHz
Memory Device [1] Manufacturer: Undefined
Memory Device [1] Part Number: F3-12800CL9-4GBXL
Memory Device [1] Device Locator: A1_DIMM1
Memory Device [1] Bank Locator: A1_BANK1
Memory Device [1] Speed: 800 MHz
Memory Device [2] Manufacturer: A1_Manufacturer2
Memory Device [2] Part Number: Array1_PartNumber2
Memory Device [2] Device Locator: A1_DIMM2
Memory Device [2] Bank Locator: A1_BANK2
Memory Device [2] Speed: 0 MHz
Memory Device [3] Manufacturer: Undefined
Memory Device [3] Part Number: F3-12800CL9-4GBXL
Memory Device [3] Device Locator: A1_DIMM3
Memory Device [3] Bank Locator: A1_BANK3
Memory Device [3] Speed: 800 MHz
SMBIOS Table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LPC F718XX
Base Adress: 0x0480
Hardware Monitor Registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF A3 00 00 01 FF FF 00 00 00 01 00 55 4C 00 30
10 00 00 00 00 00 00 06 FF FF FF FF FF FF FF FF FF
20 C7 A7 85 6D 4A A8 C9 C9 C7 FF FF FF FF FF F3 B2
30 7A D7 FF FF FF FF C9 C8 75 85 FF FF FF FF FF 00
40 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 00 00 FF FF 04 00 00 00 FF 0A 40 26 FF 00
70 FF FF 3F FF 35 FF 29 FF 00 00 00 00 00 40 00 00
80 FF FF 50 55 6D 55 55 46 FF FF FF FF FF FF A8 FF
90 00 00 00 00 14 FF 17 FF 44 02 00 15 55 05 99 1A
A0 02 29 00 FF 02 1D 3C 32 28 1E FF FF AC AC AC 0D
B0 06 4D 00 F3 03 FF 41 41 41 32 FF FF FF FF A6 1D
C0 05 5F 00 B2 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 00
F0 00 00 00 00 00 00 33 FF 02 8C FF 00 FF 00 FF FF
CPUID
Processor 0
Processor Vendor: AMD
Processor Brand: AMD FX(tm)-6300 Six-Core Processor
Family: 0x15
Model: 0x2
Stepping: 0x0
CPUID Return Values
CPU Thread: 0
APIC ID: 0
Processor ID: 0
Core ID: 0
Thread ID: 0
Function EAX EBX ECX EDX
00000000 0000000D 68747541 444D4163 69746E65
00000001 00600F20 00060800 3E98320B 178BFBFF
00000002 00000000 00000000 00000000 00000000
00000003 00000000 00000000 00000000 00000000
00000004 00000000 00000000 00000000 00000000
00000005 00000040 00000040 00000003 00000000
00000006 00000000 00000000 00000001 00000000
00000007 00000000 00000008 00000000 00000000
00000008 00000000 00000000 00000000 00000000
00000009 00000000 00000000 00000000 00000000
0000000A 00000000 00000000 00000000 00000000
0000000B 00000000 00000000 00000000 00000000
0000000C 00000000 00000000 00000000 00000000
0000000D 00000007 00000340 000003C0 40000000
80000000 8000001E 68747541 444D4163 69746E65
80000001 00600F20 10000000 01EBBFFF 2FD3FBFF
80000002 20444D41 74285846 362D296D 20303033
80000003 2D786953 65726F43 6F725020 73736563
80000004 2020726F 20202020 20202020 00202020
80000005 FF40FF18 FF40FF30 10040140 40020140
80000006 64006400 64004200 08008140 0040C140
80000007 00000000 00000000 00000000 000007D9
80000008 00003030 00000000 00004005 00000000
80000009 00000000 00000000 00000000 00000000
8000000A 00000001 00010000 00000000 00001CFF
8000000B 00000000 00000000 00000000 00000000
8000000C 00000000 00000000 00000000 00000000
8000000D 00000000 00000000 00000000 00000000
8000000E 00000000 00000000 00000000 00000000
8000000F 00000000 00000000 00000000 00000000
80000010 00000000 00000000 00000000 00000000
80000011 00000000 00000000 00000000 00000000
80000012 00000000 00000000 00000000 00000000
80000013 00000000 00000000 00000000 00000000
80000014 00000000 00000000 00000000 00000000
80000015 00000000 00000000 00000000 00000000
80000016 00000000 00000000 00000000 00000000
80000017 00000000 00000000 00000000 00000000
80000018 00000000 00000000 00000000 00000000
80000019 F040F018 64006400 00000000 00000000
8000001A 00000003 00000000 00000000 00000000
8000001B 000000FF 00000000 00000000 00000000
8000001C 00000000 80032013 00010200 8000000F
8000001D 00000121 00C0003F 0000003F 00000000
8000001E 00000010 00000100 00000000 00000000
CPU Thread: 1
APIC ID: 1
Processor ID: 0
Core ID: 1
Thread ID: 0
00000001 00600F20 01060800 3E98320B 178BFBFF
8000001E 00000011 00000100 00000000 00000000
CPU Thread: 2
APIC ID: 2
Processor ID: 0
Core ID: 2
Thread ID: 0
00000001 00600F20 02060800 3E98320B 178BFBFF
8000001E 00000012 00000101 00000000 00000000
CPU Thread: 3
APIC ID: 3
Processor ID: 0
Core ID: 3
Thread ID: 0
00000001 00600F20 03060800 3E98320B 178BFBFF
8000001E 00000013 00000101 00000000 00000000
CPU Thread: 4
APIC ID: 4
Processor ID: 0
Core ID: 4
Thread ID: 0
00000001 00600F20 04060800 3E98320B 178BFBFF
8000001E 00000014 00000102 00000000 00000000
CPU Thread: 5
APIC ID: 5
Processor ID: 0
Core ID: 5
Thread ID: 0
00000001 00600F20 05060800 3E98320B 178BFBFF
8000001E 00000015 00000102 00000000 00000000
AMD CPU
Number of Cores: 6
Threads per Core: 1
Timer Frequency: 14.31818 MHz
Time Stamp Counter: Invariant
Estimated Time Stamp Counter Frequency: 3500.16 MHz
Estimated Time Stamp Counter Frequency Error: 0.37157 Mhz
Time Stamp Counter Frequency: 3500.07 MHz
MSR Core #1
MSR EDX EAX
C0010000 00000000 00000000
C0010004 00000000 00000000
C0010015 00000000 09000011
C0010064 800001A8 00001419
C0010071 01000006 3C011E16
MSR Core #2
MSR EDX EAX
MSR Core #3
MSR EDX EAX
MSR Core #4
MSR EDX EAX
MSR Core #5
MSR EDX EAX
MSR Core #6
MSR EDX EAX
Miscellaneous Control Address: 0xC3
Time Stamp Counter Multiplier: 17.5
AMD Display Library
Status: OK
Number of adapters: 6
AdapterIndex: 0
isActive: 1
AdapterName: AMD Radeon R9 200 Series
UDID: PCI_VEN_1002&DEV_679A&SUBSYS_A003174B&REV_00_4&DE2C59F&0&0010A
Present: 1
VendorID: 0x1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0x551884C0
AdapterIndex: 1
isActive: 0
UDID: PCI_VEN_1002&DEV_679A&SUBSYS_A003174B&REV_00_4&DE2C59F&0&0010&02A
Present: 1
VendorID: 0x1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterIndex: 2
isActive: 0
UDID: PCI_VEN_1002&DEV_679A&SUBSYS_A003174B&REV_00_4&DE2C59F&0&0010&03A
Present: 1
VendorID: 0x1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterIndex: 3
isActive: 0
UDID: PCI_VEN_1002&DEV_679A&SUBSYS_A003174B&REV_00_4&DE2C59F&0&0010&04A
Present: 1
VendorID: 0x1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterIndex: 4
isActive: 0
UDID: PCI_VEN_1002&DEV_679A&SUBSYS_A003174B&REV_00_4&DE2C59F&0&0010&05A
Present: 1
VendorID: 0x1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterIndex: 5
isActive: 0
UDID: PCI_VEN_1002&DEV_679A&SUBSYS_A003174B&REV_00_4&DE2C59F&0&0010&06A
Present: 1
VendorID: 0x1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
GenericHarddisk
Drive name: ST3000DM001-1ER166
Firmware version: CC25
ID Description Raw Value Worst Value Thres Physical
01 Read Error Rate 58D9900D0000 99 119 6 -
03 Spin-Up Time 000000000000 94 95 0 -
04 Start/Stop Count DC0200000000 100 100 20 732
05 Reallocated Sectors Count 000000000000 100 100 10 -
07 Seek Error Rate F64D90000000 60 69 30 -
09 Power-On Hours (POH) E20900000000 98 98 0 2530
0A Spin Retry Count 000000000000 100 100 97 -
0C Power Cycle Count 140200000000 100 100 20 532
B7 SATA Downshift Error Count 000000000000 100 100 0 0
B8 End-to-End error 000000000000 100 100 99 -
BB Reported Uncorrectable Errors 000000000000 100 100 0 0
BC Command Timeout 000000000000 100 100 0 0
BD High Fly Writes 000000000000 100 100 0 -
BE Temperature Difference from 100 290026290000 57 59 45 59
BF G-sense Error Rate 000000000000 100 100 0 -
C0 Emergency Retract Cycle Count 230000000000 100 100 0 -
C1 Load Cycle Count 5C6100000000 88 88 0 -
C2 Temperature 290000000C00 43 41 0 41
C5 Current Pending Sector Count 000000000000 100 100 0 -
C6 Uncorrectable Sector Count 000000000000 100 100 0 -
C7 UltraDMA CRC Error Count 000000000000 200 200 0 -
F0 Head Flying Hours 9A0400003734 253 100 0 -
F1 Total LBAs Written 1A4FBF540100 253 100 0 -
F2 Total LBAs Read F32B2F4DF500 253 100 0 -
Logical drive name: A:\
Format: NTFS
Total size: 3000457228288
Total free space: 2168010870784
GenericHarddisk
Drive name: SanDisk SDSSDHP256G
Firmware version: X2316RL
05 Reallocated Sectors Count 000000000000 100 100 - -
09 Power-On Hours (POH) CB0800000000 100 253 - 2251
0C Power Cycle Count 1C0200000000 100 100 - 540
A6 Unknown 010000000000 100 100 - -
A7 Unknown 250000000000 100 100 - -
A8 Unknown 5C0000000000 100 100 - -
A9 Unknown A90100000000 100 100 - -
AB Unknown 000000000000 100 100 - -
AC Unknown 000000000000 100 100 - -
AD Unknown 160000000000 100 100 - -
AE Unknown 670000000000 100 100 - -
BB Reported Uncorrectable Errors 000000000000 100 100 - 0
C2 Temperature 340010003500 53 48 - 52
D4 Shock During Write 000000000000 100 100 - -
E6 GMR Head Amplitude 490000000000 100 100 - -
E8 Endurance Remaining 640000000000 100 100 4 -
E9 Power-On Hours (POH) AC1600000000 100 100 - -
F1 Total LBAs Written 610900000000 253 253 - -
F2 Total LBAs Read 320C00000000 253 253 - -
F3 Unknown 000000000000 100 100 - -
Logical drive name: C:\
Format: NTFS
Total size: 255219200000
Total free space: 102394372096
Only if I'm doing it accidentally. Which seems kinda hard. I did put the thing together myself, but I did my best to follow the standard installation procedure. I know these things aren't made for overclocking, and I wouldn't try.
