Motherboard panel wiring help
caleb.lee.a.ragan
Ok, so I built a computer about 8 months ago or something, after moving from BC to Alberta I completely disassembled my PC, and I didn't take pictures of it or anything, was a little too confident in my PC skills
Anyways I rebuilt my PC, and everything was easy to build, but now I'm stumped on the front panel wiring.
I saw another post and it said that I should remove all the panel connectors from my motherboard and touch the tops of the connectors with a screwdriver to see if it turns on otherwise it was defective, after trying to no success I touched CLRTC with my screwdriver and it turned on. I thought it might be fixed so I plugged in a monitor and nothing appeared, so I then touched the power connectors with my screwdriver and it turned off
So I was able to turn it off with the power connectors
But not able to turn it on
So I just wanna know if I might have just busted my motherboard some how
I also recorded a video because I'm really bad at explaining things at times https://youtu.be/01amCBXnrOI
Motherboard: P8Z68-M PRO
And I have read the manual and i followed what it said
If you removed the CLRTC jumper replace it. It wont turn on if it's not jumpered properly
That has nothing to do with it turning on or off. You should be shorting the pwr pins on the system panel header
Hey thanks paul, i lost the jumper somewhere so i ripped one out of another computer and put it on, I unplugged it and held the power button till it didn't have any power left and I tried turning it on and it worked, thanks again Paul
