Question Motherboard parts
Jul 19, 2021
6
Can someone please tell me the best compatible
32Gb ram
Cpu
500GB SSD or 1TB
For this motherboard A320M-A PRO (MS-7C51)
I would appreciate it.
artavasdes
121
8
615
12
32Gb ram
Cpu
500GB SSD or 1TB
If you aren't on an extremely tight budget, I wouldn't recommend using any a320 motherboard especially because you are planning to use 32gb ram. Do you mind telling us what cpu you are using?
I would honestly just spend an extra 30-40 dollars and get a decent b450 motherboard that has 4 ram slots.
kanewolf
32Gb ram
Cpu
500GB SSD or 1TB
The manufacturer lists the compatible CPUs -- https://www.msi.com/Motherboard/support/A320M-A-PRO#support-cpu
The 3000 series CPUs are the newest that motherboard supports. For gaming a 3600 CPU would be the best choice, IMO.
2x16GB RAM (3200 MAX) would be the choice for RAM.
That motherboard does NOT have an M.2 slot, so your best choice for storage is an MX500 SATA SSD.
Jul 19, 2021
6
6
Thanks ill try to upgrade
