Hello,
I've been having an issue where after i open the computer the keyboard and mouse will work for some seconds and then not respond to anything. The rbgs of both are ON but they do not respond to clicks nor mouse movement. Uplug and plug does the same thing, on any port. Same with audio. Before this i had some windows problems that i mention here(random shutdown and sleep). The PC is two months new, i don't get why this happens. Would it be the motherboard? does it need replacement?
(btw the same happens in bios, input devices just stop responding after some time. I have to plug and unplug every 5sec to make things done)
EDIT1: The problem doesn't occur so much anymore. The "ikhq" keys are being pressed randomly along with windows key, without me doing anything, even with unplugged keyboard. I disabled windows key for now.
EDIT2: Done stress tests on cpu and gpu to see if it is overheating or power issue but it performed normally.
EDIT3: It also at random times blue screen with text in middle appears saying shutting down or sleep. Waiting for it to happen again and check the event viewer to find the reason.
