Motherboard post issues
xozomk
24
Hi,I am having issues wit h my new motherboard.I assembled the system yesterday ,and it posted fine and is working.However ,when I shut the system off and turn the power switch on the back of my power supply off,the next time I got to turn the system on it will turn on for a second,then it will shut off and turn back on.After it does this it functions perfectly until I flick the power switch again.Is this normal?Should I be worried??The motherboard is an Intel DH77KC and the processor is and Intel pentium g870
Thanks
So why are you shutting of the power switch on the back of the PSU? Normally not done, so I would guess what you are doing has something to do with standby power and is normal.
