Motherboard/power supply compatibility
RayMartin423
I'm trying to determine if I'll be able to use my Gateway Newton ATX 250 Watt power supply to power my Asus FM2 Motherboard with an AMD A-series 4.1Ghz dual-core processor. Would the Newton be sufficient?
That's close but the output is 250W max on mine. I talked to TigerDirect who I ordered the motherboard and processor from and they said it should be fine as long as the motherboard fits in my computer casing which from what I can tell it should.
Well the motherboard has built in sound and video so that should help. I think I'm just going to use a 20 pin to 24 pin adaptor so I know that everything will connect and hope for the best.
If you're going to use the on-die GPU of the APU, you will be fine with that existing PSU.
