motherboard powers on but no signal on monitor
Mar 28, 2018
14
First of all im sorry for my bad english.
so for the last few days when i booted up my pc i got a black screen with this message:
:all settings have been reset to default values.
Press F1 to continue
Press f2 to run setup
Press del key to run setup menu
problem was when i would press f1 or f2 nothing would happen and neither would pressing delete.
The only way to get past this message was pressing ctrl alt delete and it would restart normal.
Once i got into Windows 10 everything worked normal i could not find Any problems.
even when restarting my computer trough windows this message would not show up,only on cold boot after my pc was shut down iT would show up.
i thought maybe i have to look for something in my bios so i would restart and i have to hold delete to get into the bios, my monitor would go dark and the power button on my monitor starts flickering like iT lost signal. I tried iT alot of times but everytime i would lose signal on my monitor
so yesterday i tried booting up, the fans are spinning and my motherboard lights up like normal but i get no signal on my monitor, and the light on my mouse and keyboard stay off , i tried restarting a bunch of times but my computer still wont post at all anymore and i could no langer press ctrl alt delete to get into my computer because nothing happens.
So after Trying to restart a bunch of times i managed to get it to start up once normally and everything ran fine even games.but after turning iT off its the same problem again
I tried resetting cmos.
Replaced the motherboard battery.
Removed everything from my motherboard and put iT back together outside the case with minimal hardware, 1 stick of ram,switching different slot. no GPU and using my onboard Graphics but i still have no signal.
I hope somebody can help me with this because i feel like i tried everything
Have you tried booting without any SSD's or hard drives plugged into your motherboard? See if that will take you to the BIOS.
