Hello,
The setup I have is:
Mobo: ASUS A8R32-MVP Deluxe - BIOS Version 7.2.24
Mem: 2 x 1Gig OCZ RAM
Video: ATI Radeon X1900 xtx
HDD: Seagate SATA Hdd
I've been using this PC for almost a year now with no/few problems. I recently moved to a new place, and after the move, I setup my PC and tried to boot it up, but it seems to crash before it can boot up the O/S.
The symptoms:
- Upon bootup I get the BIOS splash screen graphic.
- The screen goes black very briefly and the BIOS splash comes up again but the image is distorted/corrupted.
If I press tab to view the POST messages:
- I get the following output:
Speed : 2.40Ghz
DRAM Clocking = 400 MHz
Dual-Channel DRAM Mode
Press DEL to run Setup
Press F8 for the BBS POPUP
1 AMD North Bridge, Rev E4
Initializing USB Controlleres .. Done.
2048MB OK (Installed Memory Size:2048MB)
Auto-Detecting 3rd Master..IDE Hard Disk
Auto-Detecting 3rd Slave...ATAPI CD-ROM
3rd Master: ST3300622AS 3.AAD
Ultra DMA Mode-6, S.M.A.R.T. Capable and Status OK
3rd Slave : PLEXTOR DVDR PX-716A 1.09
Ultra DMA Mode-4
Auto-detecting USB Mass Storage Devices ..
00 USB mass storage devices found and configured.
I have not changed the configuration or added any components since my move (i.e. nothing has changed between the time the PC was last working and now, except having to hook it up again). I've opened it up and checked that all the connections are secure (they seem okay). I've tried booting from the DVD Drive as well in case the problem was with the HDD. I am able to get into the BIOS config by pressing delete and have tried resetting the settings back to factory defaults. I've also tried disabling the USB controller. The symptoms/results are always the same. I did manage to bootup the PC and get into the O/S once only out of perhaps 15-20 tries when I first setup the PC after rebooting a few times. It hasn't worked after that.
Would anyone maybe know where the problem might be or have any suggestions as to what steps to take next? I'm suspecting the motherboard, but unfortunately I think socket 939 has been phased out so that will mean having to buy a new CPU as well 🙁 I've written ASUS customer support but they have not got back to me yet and it has been a week and a half now.
The symptoms:
Speed : 2.40Ghz
Ultra DMA Mode-4
