motherboard problems for an i5 4690k
patchley
11
Hello everyone, I'm fairly new to pc building, as i have only replaced my gpu and psu. I recently purchased an intel i5 4690k only to find out that it doesn't fit into my AMD 760g motherboard. Though i have found motherboards online that are compatible with the i5 4690k, i'm not sure if the rest of my build will fit in the motherboard. Could someone link me a a decent motherboard? Not looking for the absolute best. Wanting to spend around 100$.
Here is my build:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883229437
geforce gtx 760 is the new gpu and XFX TS 550W 80+ Gold is the new psu
Thanks
It is compatble with the PSU and everything else however I need to see what is your motherboard form factor and I need to know whether your case supports ATX or not.
I should've asked this before .-.
here is the motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813130630
here is the case http://www.walmart.com/ip/EOS-204S-Mid-Tower-Gaming-Case-with-Power-Efficient-Power-Supply-Black/26922119
