sprizz324 Distinguished Jul 7, 2011 19 4 18,515 Jan 22, 2018 #1 Can't seem to connect Z270E Asus board to my Evga GTX 1080 FTW GPU. Even Geforce driver dowmload says no compatible device. What's up with that?
Solution rgd1101 Jan 22, 2018 sprizz324 : As i said ,it's lit, .both 8 point plugins are attached . I thought it might be a driver .Geforce couldn't locate it . The error said no compatible device, hardware issue. try reseating the card.
rgd1101 Don't Moderator Nov 7, 2011 73,303 3,853 176,290 Jan 22, 2018 #2 Which slot? got the pcie power cable in? Upvote 0 Downvote
sprizz324 Distinguished Jul 7, 2011 19 4 18,515 Jan 22, 2018 #3 rgd1101 : Which slot? got the pcie power cable in? Top slot under cpu ,card is lit up no recognition in bios,no recognition from Geforce driver downloader either.. Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 73,303 3,853 176,290 Jan 22, 2018 #4 can the monitor is connection to it, and not to the mobo output? what about the pcie power cable? Upvote 0 Downvote
M MickyDee Distinguished Aug 22, 2007 52 0 18,640 Jan 22, 2018 #5 As rgd1 101 asked, after you plugged in the card did you hook up both 8 pin power connectors to the card ? Upvote 0 Downvote
sprizz324 Distinguished Jul 7, 2011 19 4 18,515 Jan 22, 2018 #6 As i said ,it's lit, .both 8 point plugins are attached . I thought it might be a driver .Geforce couldn't locate it . Upvote 0 Downvote
sprizz324 Distinguished Jul 7, 2011 19 4 18,515 Jan 22, 2018 #7 MickyDee : As rgd1 101 asked, after you plugged in the card did you hook up both 8 pin power connectors to the card ? gotta get some stuff done. Be back in an hour or so. Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 73,303 3,853 176,290 Jan 22, 2018 Solution #8 sprizz324 : As i said ,it's lit, .both 8 point plugins are attached . I thought it might be a driver .Geforce couldn't locate it . The error said no compatible device, hardware issue. try reseating the card. Upvote 0 Downvote Solution
