installed new computer system with asus P5P43TD pro motherboard. everything works fine exepct none of the usb ports on the motherboard or on the case work. any help would be greatly appreciated
Have you checked in device manager to see if they have drivers working ? You will get a yellow triangle if there is an issue.
As for the case ones i assume you hace the headers conected correctly ?
