I assembled a system with Gigabyte GA-K8N51GMF-9 mobo with athlon64 3500+ 1gb ram and 250gb hard disk etc
the problem i faced is failure to POST if kept turned off for few hours (OFF from main power outlet) since i had a warranty i asked my PC assembler to figure out the problem.
they simply told me that it was a bad PSU and replaced it. this happened 3 times (replaced 3 PSUs)
actually the same PSU works fine in other systems and it will work in my system if kept ON continuously. i think it is a serious problem with Gigabyte motherboards.
i did a small research and found these links :
http://forums.pcper.com/showthread.php?p=3663475#post3663475
http://www.hardforum.com/showpost.php?p=1028898900&postcount=265
http://forums.pcper.com/showpost.php?p=3672473&postcount=7
2 days later.. i asked my PC builder to replace my mobo
my new mobo model : GA-K8NF9 Ultra(Rev 2.x) nforce4 ultra/SLI
now i'm experiencing the same boot up problem. i'm currently typing this from my laptop.
Please advice me regarding this matter.
more info about my motherboards (comparison)
http://www.gigabyte.com.tw/Products/Motherboard/Products_ComparisonSheet.aspx?ProductID=1939,2268
