M MMandevil Honorable Aug 23, 2013 22 0 10,520 Apr 23, 2014 #1 Does the Z87 Support Ivy bridge or sandy Cpu's? I was wondering if I should get the I5 4670k or the 2600k for ivy.
Solution M M MMandevil Apr 23, 2014 laviniuc : z87 supports just haswell so only the i5 4670 would work. the 2600 needs a Z77 (or other 7 series chipsets) Is it better to get a haswell cpu or a Sandy, I hear the haswell runs really hot, especially when overclocking.
laviniuc Judicious Nov 29, 2013 5,504 18 32,415 Apr 23, 2014 #2 z87 supports just haswell so only the i5 4670 would work. the 2600 needs a Z77 (or other 7 series chipsets) Upvote 0 Downvote
M MMandevil Honorable Aug 23, 2013 22 0 10,520 Apr 23, 2014 Solution #3 laviniuc : z87 supports just haswell so only the i5 4670 would work. the 2600 needs a Z77 (or other 7 series chipsets) Is it better to get a haswell cpu or a Sandy, I hear the haswell runs really hot, especially when overclocking. Upvote 0 Downvote Solution
