Motherboard - RAM problem
izghitu
Hi,
I have one new Asus Prime X370-PRO Socket AM4 motherboard and ADATA XPG DDR4 2666 2x4GB RAM.
THe problem I am facing is that the Motherboard will not boot with the RAM. I tried some other RAM on the motherboard and it works fine. I also tried the ADATA RAM on another motherboard and it worked fine as well. Just the 2 will not work together although the motherboard specs say that it is compatible with 2666 MHz RAM.
Does anyone have any ideas about if I am doing something wrong?
Please help. Thanks!
So there's nothing I can do about it? perhaps apply a bios patch or something?
Please let me know
Thanks
Thanks, I have used my friend's RAM to boot it and updated the BIOS to the latest. It started working after that. Problem solved.
