Question Motherboard repair help pls
Feb 28, 2025
5
CPU: Ryzen 5600
CPU cooler: AMD
Motherboard: Asus
Ram: G.Skill Trident Z Neo 2x16
SSD/HDD: SK Hynix 256GB m.2
GPU: Radeon 5500
PSU: EVGA 600 watt
Chassis:
OS: windows 10
Monitor: Gigabyte M270
I picked up an used Asus Prime x570 pro; thinking how hard could it be too fix. I have even more respect for repair techs.
The board turns on but doesn't post. I have tried clearing the cmos, trying different components, and unfortunately this board doesn't have a way to flash the bios without posting first. I used a power supply tester to make sure that was good to go. And other stuff work with this gens am4.
I tried using a post card. The TL631, but all that told me was power is good and a solid red light on RST.
THE board also looks to be in good shape. I cleaned it up a bit with isopropyl and a q tip.
You might want to start by prefacing your build with the following;
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model.
You might want to grab a CH341A BIOS programming toolkit, reflash the BIOS with the latest version, then clear the CMOS and see if that revives the board.
A POST speaker would be helpful in this scenario.
Reactions: KingVegeta
Thank you, and I will update the post. I think I have that tool. Got it yesterday. Do you know a good video of website I can learn how to use it?
A
Thank you. Ok I understand some of that. Some how cmos/cmos battery is shorted. I can take a look in those area with a microscope and see if something is bridged. What i don't get is "reset line is held low"?
Are you 100% sure the cmos jumper is not in the reset position? I don't even want to imagine what would happen if you try to flash the BIOS while the board is in reset mode (maybe nothing, but I would not like to try it).
Yo i wish that was the problem. I swear I'm not trolling but I see the clear cmos pins with no jumper on them. This board doesn't have a switch or anything to do that. I need to find an image board to show you all pictures. But if it is that simple I'm gonna loose it 😆
