Motherboard Replacement Compatibility?
Lunamode
9
Okay, I currently have a Dell XPS 8500, it is a Micro ATX.
These are the motherboard specifications for this pc: http://www.findlaptopdriver.com/dell-xps-8500-mainboard-specifications/
I want to change my motherboard, and I'd like to know If I could replace my current motherboard with this: http://www.amazon.com/dp/B00K23BY6Y/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=28GDO9BWV0GIJ&coliid=IS5WJVWWOOTG8
Would I need to buy something more with this new motherboard(other than the graphics card and CPU, I realize I would need to replace these)?
The graphics card on that XPS is probably integrated into the CPU, so you would just need to buy the motherboard and CPU. Everything else - RAM, HDD, PSU should all be compatible.
Okay thanks! Hopefully everything works out!
