Question Motherboard Replacement
Aug 5, 2025
hello, i need to replace my motherboard which is a B560M-A Pro dont think i can buy the same one. i would like it just be like for like take old one out and new one in with same wires and such hopefully if you could recommend an easy swap pls, price between £100-£150 thank you
Out of curiosity, what are the rest of your specs? Please list the specs to your build like so(with the exception of the motherboard):
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. If the reason for your board's demise was due to it being lackluster in design, then you should plan ahead and look at something that has a better VRM design.
Using PCPartPicker;
https://uk.pcpartpicker.com/products/motherboard/#s=39&sort=price&c=149,154
the platform is discontinued;
https://www.intel.com/content/www/us/en/products/sku/196645/intel-b560-chipset/specifications.html
Ebay would be your next option or scouring Amazon.co.uk for one, if you want an exact replacement. You can still look at a Z590 chipset;
https://uk.pcpartpicker.com/products/motherboard/#s=39&sort=price&c=154,148
CPU: i7-11700
CPU Cooler: I think is a Coolmaster 212 EVO
Motherboard: B560M-A Pro
Ram: Corsair 2x 16GB 3000mhz
SSD/HDD: 2TB WD SN770
GPU: 2070 though i also have 4080 and 1080ti 4080 maybe to much?
PSU: Corsair RM750x around 2 years old
Chassis: not sure the exact but its a Lian Li one 216 maybe
OS: Win 11
Monitor: Asus 4k
I'm replacing because messed up during cleaning and bent allot of the CPU pins.
