Question Motherboard RGB Header Help
Aug 27, 2020
So basically I am planning to build a PC with the Asrock B550 Extreme4 Motherboard and I was confused about the headers required to make the Asus ROG Strix LC 360 function so I can change the colours in software, I know the AIO comes with a splitter for the RGBs on the fans so you can connect them to one header, but I just need to know if there is a header on the motherboard to do this.
Thanks for reading and your help!
alexbirdie
Proper
Feb 20, 2020
214
40
140
6
From Asus-home-page:
Fan: 3 x ROG Designed A-RGB radiator FAN
That means:
"So I would plug the fans into the splitter asus supplies with the AIO and connect the other side to a 5v ARGB header? Then it should all work fine? "
YES.
Latest posts
