Here's what I'm trying to do: I have 3 PWM case fans connected together with a splitter that is also connected to the PSU with a molex, and has PWM connector that passes speed from one of the fans and goes into the motherboard. I also have Corsair H60 with it's own fan not connected with others. I'm trying to make this all work with AsRock Z87M Extreme 4 motherboard.
I ended up with 3 cables that I need to connect. One cable from the H60 water pump, one from it's fan, and one from my case fan splitter.
How to do it right? I tried connecting splitter to CHA_FAN1, because it seems to support PWM, but the fans start running on full speed as soon as my desktop appears. The only other connector that seems to support PWM is the CPU_FAN1, but I have my CPU fan connected there.
Should CHA_FAN1 work? Maybe I should connect CPU fan to the splitter also and then all fans from the splitter to CPU_FAN1? Maybe it's a matter of upgrading BIOS, or changing it's settings?
Here's a link to a photo of the motherboard with all the connectors.
