Motherboard ryzen build help
remaGGamer1
38
I want a gaming pc and i picked ryzen because everyone says that it is the best so i need a motherboard and i picked Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard and it says it supports 2933 speed ram and 3200 and i want 3000 do you have any suggestions for a motherboard under 130 with 3000 speed ram ryzen.if you find a good motherboard for oc and all other things
Thank you for your time to help me
No AM4 motherboard runs any ram at 3000mhz, Ryzen doesnt have the dividers for it, 2933 is the closest you can get to it, the next steps up are 3066mhz, 3200mhz, 3333mhz, 3466mhz < (Note also no 3400) so on so forth.
With the Gigabyte AB350-Gaming 3 (rev. 1.0) board have problem running at 2933 (not much difference from 3000mhz i think) with xmp or what?
I heard that the rams have problem with this board and they need to realese a bios update
