Hello, I wanted to ask for help in regards to a front case fan not working. I have an ASUS M5A97 motherboard and a NXZT case. My fan is not spinning and I'm not sure if it's a problem with the motherboard or the cable. The motherboard displays it the speed as N/A, so it looks like it is not being detected it at all. Would you recommend me trying to use the cable from the working fan to see if it is a connector problem and also try swapping out the fan in the front with the working fan to see if the fan itself is broken?
