[SOLVED] Motherboard settings not applying
Feb 15, 2025
13
4
15
I am encountering a weird issue.
Every time I change the setting soc/uncore oc mode to disabled by the next time I open the bios it sets it back to enabled. I have tried to reset it by removing the battery it defaults to disabled ,but if I enter the bios again it sets it back to enabled. I am on the newest bios version. It only happens with this setting other settings behave normally.
Gigabyte b550m ds3h ac
R 5600
32 GB 3200mhz ram
For the sake of relevance, please mention the BIOS version you're on for your motherboard. As for the ram you're working with, got a link to said ram kit? Does the time for your motherboard also reset to 00:00?
Might be worth a read;
I would use Ryzen master's Curve Optimizer instead if you'd like to optimize the system.
Reactions: hamster02
Thank you I tried what the post suggested and now it is behaving normally.
